| | | Forums66 Topics128,050 Posts1,055,671 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 23 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 23 | I haven't been on here in quiet a while just bought a 1966 I think C60 with a 14 ft dump 327 5spd electric 2spd local truck was bought new at our local chevy dealer no rust southern truck my vin is HC6536A118805 if anyone can decode it Thanks in advance | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Where on the truck did you find this VIN? | | | | | Joined: Mar 2008 Posts: 23 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 23 | Top of the door opening drivers side | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I cannot find information in GM’s Heritage Library.
Do you have a Shop Manual - ID information might be near the front of that manual. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Here's your serial number break down; HC6536A118805 H = Heavy Duty C = Conventional Cab with Gas Engine 65 = 2-ton with 175" wheel base 3 = Model 03 = Cab 6 = 1966 A = Atlanta Plant 118805 = Unit Number starting with 100001, 18,805th unit out of Atlanta. Mike B  | | |
