| | | Forums66 Topics128,208 Posts1,057,452 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | I have a '52 panel with a 350. While installing a new radiator, I switched the thermostat housing to a TransDapt aluminum swivel housing with an O ring. This was back in the summer. It now leaks from what appears to be at the joint where the neck meets the base. I plan to put an aluminum one piece on (with a gasket) but I don't know what size and pitch the original bolts were (I thought I put them in a place where I would remember where they were. But that didn't work!). I want to get everything ready before I start so I don't have to take the old one off, go to the bolt store, then come back to complete the job. The bolts that came with the TransDapt housing are cap bolts that use a Allen key to tighten and I don't think they will work (they recess into the base). Also, I've found on-line that some people recommend putting studs in the manifold and attaching the housing with ny-lock nuts. Any thoughts on this? Thanks.
It's a small world, but I wouldn't want to paint it.
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | 3/8-16 NC---takes a 9/16 socket or wrench.
Evan
| | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | Thanks, coilover. I forgot to ask what the length is.
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | The thickness of the thermostat housing mount ear plus 5/8 inch. Second option is to hold housing with the gasket in place and stick a lead pencil (or similar) down the hole and mark how deep it goes. Subtract a 1/4 inch off this measurement.
Evan
