7 members (TUTS 59, klhansen, frogfarmer, 1955 1 Series, Wally / Montana, papas52, 1 invisible),
115
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,161 Posts1,056,906 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12955 10/13/2004 5:08 PM | Joined: Sep 2003 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 65 | Hey Wrenchers, I'm in the process of mounting my carb to the intake manifold. Currently, I have one gasket/plastic spacer that is approximately 1" thick and also 1 felpro gasket. Should I have two felpro gaskets, 1 for each side of the plastic spacer?
thanks pork
235 '59 1/2 ton bbw, fleetside
1959 Chevy Fleetside 3100 Series BBW
#12956 10/13/2004 7:55 PM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 |
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
#12957 10/13/2004 9:49 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I usually skip the gasket between the manifold and the spacer and just use the one between the carb and the spacer with no problems yet.
#12958 10/14/2004 2:13 PM | Joined: Sep 2003 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 65 | ok great...I have 2 responses (thank you), both of which say their will be ok, but both using different gasket quantities.....
so either way I'll be Okay, right?
#12959 10/14/2004 6:23 PM | | Anonymous Unregistered | | Anonymous Unregistered | Make sure that the little cutouts in the spacer and gasket are aligned right so as not to block the vacuum passage for the power valve circuit. If you inadvertantly cover up that port on the base of the carb, the power valve will be on constantly and your gas mileage will go down. | | |
#12960 10/15/2004 2:41 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You can use a gasket between the spacer and the manifold if you want but Chev did not use one originally.
See the USA in your vintage Chevrolet! My Blog | | |
