0 members (),
138
Mod | | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 53 Rusty Nuts | | Rusty Nuts Joined: Jan 2019 Posts: 53 | I recently bought a 14 bolt rear end to replace my OEM Eaton HO52 so I'd have more highway friendly gears. the WMS to WMS is about 62.5" but the pinion has an offset of nearly 2" towards to passenger side. My engine and tranny are not mounted yet fortunately. Do I need to offset my engine and tranny the same amount (about 2" towards passenger side) or do I need to find another rear end with more of a centered pinion? Obviously I am new to this. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Neither, You can use the axle as is with a centered engine and transmission. The slight offset will not be an issue at all so long as pinion and transmission shafts are still parallel, which they will be unless you goof up installing springs or engine. We have a tech tip with resources on calculating, installing, and evaluating driveline angles and such. https://www.stovebolt.com/techtips/driveline/setup/index.htmlIf you get into the PDF's you can read about driveline setups just like you're about to do and given your measurements can satisfy yourself it'll be OK. Those manuals and the basic rules in the tech tip will also help you set your pinion angle, which you'll need to do considering you're swapping axles and possibly engine. Grigg | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | Millions of Tri-5 Chevy cars ran an offset pinion with no problems. I don't see an issue as long as the pinion shaft vertical angle is correct. Jerry
| | | | | Joined: Jan 2019 Posts: 53 Rusty Nuts | | Rusty Nuts Joined: Jan 2019 Posts: 53 | very encouraging! What do you mean by "so long as pinion and transmission shafts are still parallel" In a vertical sense? I have a long bed so I'll; be using a two piece drive shaft with a carrier bearing. thanks | | | | | Joined: Jan 2019 Posts: 53 Rusty Nuts | | Rusty Nuts Joined: Jan 2019 Posts: 53 | thanks Jerry. I',m running a two part drive shaft since my truck is a long bed. Any other pointers? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Snowman, Look in the driveline setup tech tip I linked above, it clarifies Jerry's explanation and answers your questions. | | | | | Joined: Jan 2019 Posts: 53 Rusty Nuts | | Rusty Nuts Joined: Jan 2019 Posts: 53 | Ok. Thanks. Since my engine and tranny are not installed yet, do you think I ought to install them, say 1" off center towards the passenger side to reduce the overall top down driveline offsets? the write-ups don't seem to cover this aspect. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Original (or similar) engine and transmission? I'd put them right back where they came from, keep it simple.
Non original engine? Would moving it to the side a little help some other aspect of the install or make it more difficult? Either way is fine, but don't make unnecessary work for yourself. | | | | | Joined: Jan 2019 Posts: 53 Rusty Nuts | | Rusty Nuts Joined: Jan 2019 Posts: 53 | different engine, an sbc and a 700R4. thx | | | | | Joined: Feb 2004 Posts: 29,886 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,886 | Install the engine/trans on center and shorten up the forward driveline a few inches to minimize the offset angle the rear U joints have to run. It would be a pretty simple matter of moving the crossmember with the carrier bearing on it forward 3-4 inches. Jerry
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | The new transmission I believe will be a lot longer than the original, one driveshaft might do the job. Consider max length and critical speed as explained in the Spicer drive shaft manuals. | | | | | Joined: Jan 2019 Posts: 53 Rusty Nuts | | Rusty Nuts Joined: Jan 2019 Posts: 53 | | | |
