8 members (Tyler Watts, Hotrod Lincoln, Joe H, Gray_Ghost, Forty9, cmayna, JW51, NJC),
82
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2019 Posts: 53 Rusty Nuts | | Rusty Nuts Joined: Jan 2019 Posts: 53 | I have a 1955 1/2 (2nd series) 3600 with 8 lug hubs.
Will 6 lug front hubs/bearings from a 3100 truck fit my 3600? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | You have a 3/4 ton if model 3600. Hubs do not interchange with 1/2 ton. Hubs do interchange with 1 ton, still 8 lug.
Compare front spring width, you may be able to swap entire front axle from 1/2 ton. You can for 48-54, I’m not sure on 55.
Also nothing wrong with having a 3/4 ton and 8 lug wheels. Why do you want to downgrade your truck? | | | | | Joined: Jan 2019 Posts: 53 Rusty Nuts | | Rusty Nuts Joined: Jan 2019 Posts: 53 | I need to put more highway friendly rear end, like 3.73, with my 305 sbc. It seems like I will be more likely to find a 6 lug rear end, so I desire to have the same wheels front and back. | | | | | Joined: Jan 2019 Posts: 53 Rusty Nuts | | Rusty Nuts Joined: Jan 2019 Posts: 53 | Thanks for the info! I was getting desperate. Now I'm going to look for a 14 bolt rear end to fit my 1955 2nd series 3600 … and keep the 8 lugs. I understand from the links that I should be looking for the narrow dual wheel version, right?
| | | | | Joined: Jan 2019 Posts: 53 Rusty Nuts | | Rusty Nuts Joined: Jan 2019 Posts: 53 | I picked up a 14 bolt with posi and my desired gear ratio and the correct WMS to WMS distance for my 55 2nd series 3600 today! Now I can keep the 8 lug with minimal mods. Thanks for all your help. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Jan 2019 Posts: 53 Rusty Nuts | | Rusty Nuts Joined: Jan 2019 Posts: 53 | 3.73 with a G80 limited slip, …. but I just discovered the pinion has nearly a 2" offset towards the passenger side..... Is there any way to use this rear end in my truck or do I need to find one with a more "centered" pinion? New thread about centered pinion or not. https://www.stovebolt.com/ubbthread...-for-my-1956-chevy-3600.html#Post1295959
