3 members (66flea, Chris's 46 / 515, TUTS 59), 120 guests, and 2 robots.
Topics128,091
Posts1,056,445
Members48,443
#129586 05/10/2004 3:58 PM
good day everyone. I have a heidts mustangII crossmember. it looks like a nice piece easy install. the question i have is about motor mounts. what are heidts motor mounts like? or use a different brand? i plan on putting in a sb350 in my 56 stepside.is there very many options for exhaust headers using the mustangII crossmember ? want to get engine mounted in without being mounted up too high or sitting funny.anyone with any pics and driveline angle recomendations would be greatly apperciated! :rolleyes:
hey 56 -
Check out my web page http://www.wsu.edu/apache.html it's for a 59.
There's some pics in there that may help.
When you install the motor make sure the carb mounting flange (top of the intake manifold) is level with the ground. You will need to get as close as possible to setting ride height to get this correct - a little preloading may be in order to account for weight not added) is parallel with the ground - (0deg tilt).
As for headers - I put the Headman Block Huggers on - you can see a pic on my web site.
As for mounts - I used the side mounts from TCI.
I also have an M2 X-member from TCI.
Everything fits nicely - mounts clear the x-member and headers clear the mounts - even the steering shaft will make the bend easily.
59 Apache Step
78 El Camino
http://www.wsu.edu/~rsain
56 - see this thread:
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=5;t=000451
there is a good discussion of a v-8 swap - including a discussion on pinion angle that is very helpful!
- Ryan
59 Apache Step
78 El Camino
hi ryan, nice job!whereas you built your frame opposed to the factory one,i wonder how close would it be to factory frame?
What do you mean by close?
It had to be the exact same width (outside), and length. Height was determined by suspension. Taper on the front of the frame was necessity. Crossmembers went in different spots though.
So - it is the same frame, just that the rails are narrow (wider space between frame rails than stock), are box steel, and straight and NOT RUSTY!
And the body fits - so we must have done something correct!
- Ryan
59 Apache Step
78 El Camino
hey ryan i didn"t mean to offend in any way.sorry. eek lot of ideas going through my head .seen the tci frame as well. like i said you did a real excellent job! yes the angles of the drive train kinda stuff is what iam after thanks a bunch!
wasn't offended at all! grin
have fun with your swap!!
- Ryan
59 Apache Step
78 El Camino
I used a TCI,mustang 2 frontend in my 55 stepside.I used a motor mount setup from Golden State Parts,item no.6-416,with motor mounts no.6-416MP.Cost was around $80.This mount setup goes from framerail to framerail,just center it and weld it in.A very easy install.I had to use blockhugger headers,for steering clearance.I set the engine height so it was level,placing a level ontop of the intake manifold,where the carb mounts.Of course to do this you must have the tranny in and mounted at the rear to get it leveled accurately.This setup has worked out very good for me. Dale
