5 members (Jeff Ogden, cmayna, TexasA&M48Truck, 1955 1 Series, HandyAndy), 129 guests, and 3 robots.
Topics128,210
Posts1,057,465
Members48,471
Z
Z Offline
On the outside of my differential on my 53 Chevy truck there are 3 bolts evenly spaced on the front of the case near the torque tube These bolts have double nuts on them.
What is their function ????………..COULD THESE BE WHAT HOLDS THE REAR OF THE TORQUE TUBE IN PLACE ???
One of them is dripping oil and I am fearful of trying to correct this leak until I know what it`s purpose is.
Thanks in advance...….J
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
Pinionshaft bearing lock screws. They are rear end bearing retaining screws and hold the propeller shaft /pinon bearing in place within the torque tube. The torque tube is pressed into the front half of the differential housing and is not meant to be separated.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Z
Z Offline
Thanks for letting me know what these screws are.
It's shown in the diagram in the shop manual. Mine is also weeping. If we keep the torque tube setup this summer I'll take it out and seal it up a bit better.
1953 Canadian GMC 9314 w/ (factory) Chevy 235
Z
Z Offline
I cannot seem to locate that diagram In my Chevy truck manual for the 1948-1953 trucks where it shows those lock screws....under rear axle section page 4-21, it does show the differential and I can clearly see the pinion bearing but not the lock screws...I am trying to visualize" how" those lock screws perform their function of securing the pinion bearing.
Here is an exploded view
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
This illustration might show one of the adjusting nuts/bolts?
Which year(s) and page(s) Shop Manuals (etc) are being referenced above (by Lindsey, zoegrant, and sstock)?
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Thanks, sstock,
Sorry to be so thick:
On that illustration: what is/are the number(s) for the parts in question?
One or two lock screws/nuts in that illustration?
Screws found in section 5.452 part number 358073
Pinch Nuts in section 8.916
Need Three of each
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
part number 358073 on the screws
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Z
Z Offline
Thank you for this info and pictures. I took out he leaking bolt today to clean it up and used some high tack sealant on it....hopefully it took care of the dripping..J.
How about a copper washer underneath the nut?
1951 1 Ton Completed
That would work because the nut is just a cinch nut
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
