1 members (RLB), 81 guests, and 1 robot.
Topics128,162
Posts1,056,940
Members48,458
Hey Wrenchers,
I'm in the process of mounting my carb to the intake manifold. Currently, I have one gasket/plastic spacer that is approximately 1" thick and also 1 felpro gasket. Should I have two felpro gaskets, 1 for each side of the plastic spacer?
thanks pork
235 '59 1/2 ton bbw, fleetside
1959 Chevy Fleetside 3100 Series BBW
Yes.
"Drugs are money, money is power, power is security." - Kent Heiner
Nedrow population 2212
Carbon footprint family of 2/11 tonnes of CO2/yr
I usually skip the gasket between the manifold and the spacer and just use the one between the carb and the spacer with no problems yet.
Paint & Body Shop moderator
ok great...I have 2 responses (thank you), both of which say their will be ok, but both using different gasket quantities.....
so either way I'll be Okay, right?
Anonymous
Unregistered
Anonymous
Unregistered
Make sure that the little cutouts in the spacer and gasket are aligned right so as not to block the vacuum passage for the power valve circuit. If you inadvertantly cover up that port on the base of the carb, the power valve will be on constantly and your gas mileage will go down.
You can use a gasket between the spacer and the manifold if you want but Chev did not use one originally.
My Blog
