0 members (),
66
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 96 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 96 | Hi Folks, Been a while since I last had a question for the Forum. Didn't drive my 55 - 3200 pickup very much in 2018. Had some health issues and winter came with a bang so I just parked it in the garage when it started snowing. When I realized that I forgot to check the anti freeze - I decided to go for a ride and check it when I got home. The temperature is right around zero and there's lots of snow but the roads are dry and it was a great drive. Can't wait for Spring! While driving, I noticed a knocking noise once the oil got warm. When it was cold there wasn't any noise. The engine runs smooth as silk and idles perfect. No smoke and no noise below 3000 rpm. Power is OK and I am wondering if maybe the valves are out of adjustment. While I was laid up sick last summer, a friend did an oil change for me and general "check up". He said he adjusted the valves COLD to .008 / 018. Could that be the reason for the noise? It's not very loud but it doesn't sound like a rod or main bearing. It sounds like valve train or maybe a piston pin. Any suggestions? Many Thanks, Sam ps. Antifreeze is OK
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Valves are almost always tighter when hot (especially exhausts, duh), so even if that doesn't turn out to be accurate it didn't hurt anything. They can't be too tight (at least one valve does not fully close) or the engine would run badly. | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | I'm glad to see that at least a few people aren't panicky about winding a stovebolt engine up above a fast idle. Chances are you just need a hot valve adjustment to quiet things down a little. If the oil pressure is good ad cruise speed, you're not likely to be having bearing problems. Enjoy the ride! Jerry
