7 members (R&S 51 GMC, Otto Skorzeny, crenwelge, Hotrod Lincoln, 1955 1 Series, Tronman, Wrenchman), 194 guests, and 1 robot.
Topics128,125
Posts1,056,341
Members48,440
I bought what used to be called a router speed controller for less than $20 online. They sell the same one at harbor freight too, but was out of stock. It works really well to slow down my 4 1/2 inch angle grinder. I don't need it running wide open unless I'm trying to grind off a lot, or cutting. Slowing down my sanding discs makes them easier to handle for finishing, plus they last longer, with less heat, and a whole lot quieter. I've been using my Milwaukee variable speed grinder which is much bulkier, and this speed controller works great on my smaller, light angle grinder. Wire wheels last years, instead of days when slowed down a bit. I actually bought the speed controller to slow down the air flow on my Hobbyair 2 fresh-air respirator. It blows way too much air, noisy, and makes the air warm. I can now slow it down, and use it hooked up to my welding helmet with the hose strapped to the chin area blowing fresh air in at a gentle breeze if I want. The speed controller can be used on most "universal" corded motors that use brushes. Not for use on an induction motor like on your drill press.
Moderator
Moderator
2 Offline
Sounds like a great tool tip.
https://www.amazon.com/Yescom-Varia...&hvtargid=pla-351845451838&psc=1
I have several grinders that I would like to have more than an on/off choice.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
I didn't know until just now, they have single-phase variable frequency drives(VFD) on the market for induction motors. That would be slick on a drill press, or buffer, etc.
https://www.ato.com/single-phase-vfd
H Online: Content
I use the same type of speed controller on my 1/4" capacity electric die grinder, which also serves as a light-duty tool post grinder for my lathe. It's sort of like a Dremel tool on steroids and it uses 1/4" shank grinding wheels and carbide burrs. It's a lot more versatile than the air die grinders I've had back when I was doing a lot of porting and polishing of race engine cylinder heads. Some of the speed controllers are more efficient than others. In general, "You get what you pay for!"
I made one years ago using a rheostat. Analog dial type light dimmer. I installed it in a receptacle box, male end of a drop cord fed into to it, female end out. I've been using it for years to control the speed of my dremel, 4 1/2 grinder, buffer/polisher.....etc.....
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
Clever idea! I imagine that the rheostat from an oven might also accomplish the task. I'll look into that, and post the results in this Forum (if it actually works smile ).
Thanks for the tip!
Chris
'64 Chev C20 LWB stepside (Ol'Blue)
Moderated by  MNSmith
