2 members (Bill Hanlon, Nuts&Bolts), 40 guests, and 3 robots.
Topics128,014
Posts1,055,324
Members48,419
#129526 03/08/2004 12:51 AM
anyone have a clue how to shave the handle on a 50 1/2 ton
#129527 03/08/2004 4:51 PM
From my experience the procedure is basically always the same.
Remove the handle. Fill hole (weld a small patch in or put a copper plate behind the hole and then just weld the hole shut - remove copper). Now smooth out the welds. Add your favorite body filler, prime, paint. Before you do any of this - make sure you understand how the mechanism works. In fact I would install the release mechanism first (depends on how brave you are grin ).
You'll need to order a shaved handle kit from AutoLoc (or other brand) or talk to a local alarm dealer (best idea) about getting solenoids, switches and relays (and possibly a 'popper').
Make sure you put a mechanical release in on one of your doors just in case your electrical system goes TU.
Did this get at your question?
- Ryan
59 Apache Step
78 El Camino
http://www.wsu.edu/~rsain
