1 members (Hotrod Lincoln), 69 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
I just got my 61 chev 3/4 ton back from the garage inspection, and am on the fence. Do I rebuild the front end with hard to find parts or float in something newer for power brakes/steering, etc? I'm not into restoring, just want something that works very well. If so, what years...I've read on here something will more or less bolt in, but I can't find it
1961 Chev 3/4
1977 Chev Nova
heamil: it all depends on what you are doing, Several companies make power disc kits for front spindles, doing my 59 soon. They got drop spindles even for your yr. more popular than 59, I just don't trust drums all the way around, we'll be pulling Harley with ours. If you need some company's name e=mail me I'll send ya the info back. Good luck popcorn
The Truth is out There (or under the rubble)
Definately put a complete x-member out of a later[1970's-80's] truck and gain the disc brakes too,a must for a daily driver.Even a 1964 setup with coil springs you can get parts all day long for,and the late ball joints go right in the control arms.Also time for a REZ power steering box adapter kit,dual circuit master cylinder. grin
