9 members (warlock, mick53, 55shaker, fonz8261, Ponchogl, RoadsScholar, Gdads51, Otto Skorzeny, 32Fordpuchoptop), 105 guests, and 2 robots.
Topics128,048
Posts1,055,626
#1294942 01/15/2019 4:19 AM
I have been adjusting the front brakes on my truck and when I spin the wheel it turns about half a revolution and dead stops. I try to turn it and its obviously hitting something. I have taken the wheel off a few times and am confounded what is causing it. Anyone have any suggestions? I think it does it just in reverse.
1958 Chevy Grumman Olson step van
Chaz 58 #1294944 01/15/2019 4:57 AM
Is your drum or rotor warped? Does it always catch or drag at the same spot? If you take the drum off or back the brakes off, can you still spin it?
FYI, it will help if you explain what truck, year, type of brakes on it, and any upgrades you have done.
Chris
Chaz 58 #1294959 01/15/2019 2:20 PM
Back the adjuster off a couple of clips and see if that improves. I worked in a gas station during high school and did s great many brake adjustments. I was taught to do them a little differently than is usually recommended. I tighten the adjuster until both shoes are tight and centered on the backing plate, wheel not able to turn at all. Then loosen the adjuster until the wheel spins freely. This avoids the situation where one shoe is creating some drag because the shoes are not centered on the backing plate.
Chaz 58 #1295099 01/16/2019 9:51 PM
Wheel spins good when it's off the ground. It siezes up when on the ground or rolls very slowly if at all.
Chaz 58 #1295103 01/16/2019 10:28 PM
How is the wheel bearing adjustment? If it's way loose, the drum will get misaligned from the shoes and could easily drag when there's weight on the wheel.
Chaz 58 #1295107 01/16/2019 11:08 PM
That was my thought, but I'm not sure how tight the bolt needs to be.
Chaz 58 #1295113 01/16/2019 11:45 PM
Everyone has their own way of adjusting wheel bearings. Here is what I was taught 60+ years ago. Jack the wheel off the ground and turn the nut until the wheel will not move. Then back the nut off until just a slight resistance is felt. The wheel should spin fairly easily. Then follow Hookalatch’s brake adjustments.
Chaz 58 #1295118 01/17/2019 12:04 AM
Ok, I'll give it a shot. Thanks
Chaz 58 #1295175 01/17/2019 4:03 PM
Though I'm not having any real braking issues, I've been considering checking/adjusting my front brakes, and wheel bearing etc. These procedures suggested by both Hookalatch and Justhorsenround seem the way to go. Thanks
Craig
Chaz 58 #1295347 01/18/2019 11:27 PM
I tinkered with the adjustments and they roll well now. I think I could use some new return springs for the brakes. I would think I could get them at any parts store but I'm coming up with only specialized web sites. Anyone have a source? 1958 Chevy 3400-3/4 ton.
