| | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2002 Posts: 23 Member | | Member Joined: Dec 2002 Posts: 23 | I just got my 61 chev 3/4 ton back from the garage inspection, and am on the fence. Do I rebuild the front end with hard to find parts or float in something newer for power brakes/steering, etc? I'm not into restoring, just want something that works very well. If so, what years...I've read on here something will more or less bolt in, but I can't find it
1961 Chev 3/4 1977 Chev Nova
| | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | heamil: it all depends on what you are doing, Several companies make power disc kits for front spindles, doing my 59 soon. They got drop spindles even for your yr. more popular than 59, I just don't trust drums all the way around, we'll be pulling Harley with ours. If you need some company's name e=mail me I'll send ya the info back. Good luck popcorn The Truth is out There (or under the rubble) | | | | | Joined: Mar 2003 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2003 Posts: 45 | Definately put a complete x-member out of a later[1970's-80's] truck and gain the disc brakes too,a must for a daily driver.Even a 1964 setup with coil springs you can get parts all day long for,and the late ball joints go right in the control arms.Also time for a REZ power steering box adapter kit,dual circuit master cylinder.  | | |
