3 members (FishinToms53, Gdads51, Gray_Ghost), 80 guests, and 0 robots.
Topics128,052
Posts1,055,740
#1295049 01/16/2019 11:35 AM
I rebuilt a new lower hinge pocket on the driver's side door pillar and have turned my attention to the upper pocket. The lower was easier as I was replacing the lower patch on the pillar anyway and so just fabb'd up a new pocket.
On the upper though I want to leave the pillar intact which means trying to detach the pocket from the pillar without sacrificing it.
The problem I have is that when I removed the door I had to resort to drilling out the upper bolt as the nut broke its weld and was turning. In the image below the offending loose nut is semi-hidden, in the black circle.
Has anyone managed to dismantle that pocket to replace the nuts? I will have a go at it this week but if someone has already been down that road I want to see if there are any pitfalls before I do. I used search but didn't find any relevant posts.
PS: The lower nuts are not hidden, what is the extra metal in front of the upper bolt. Is it the panel above?
Paul
1951 3100 5-window
with a '55 235/floor mounted 3-speed
Some of the story in ODSS
Most of it in The Shops Area wink
It's likely held on by spot welds. I'd suggest drilling some 1/8 holes for clecos or alignment using a drill bit for later re-installation, and then use a spot weld cutter or other means to remove the cage.
Thanks Robert, yes I was thinking about just taking to it with a wire wheel to uncover spot welds. Good thought on the alignment hole(s), I will do that.
1951 3100 5-window
