0 members (), 117 guests, and 1 robot.
Topics128,089
Posts1,056,141
Members48,436
1 Offline
Guys, it has been ages since I was here, need some info on removal of a stock ignition switch for a 1949 suburban ignition switch and no keys are currently available, do these simply unbolt from dash then remove 3 wires? I can get key made at locksmith for $20 if I bring him the ignition switch, I just can't recall after 20 years not touching one. I will post pictures of the runner/driver burb I'm moving for storage. Thanks guys for any help!
https://www.classicparts.com/1947-53-Ignition-Switch-Original-Style/productinfo/53%2D405/
https://www.classicparts.com/1947-53-Ignition-Switch-Bracket/productinfo/53%2D461/
The bracket attaches to the rear of the dash.
As I dimly reall, the switch is twisted to catch the two posts.
I do not recall if there is an attachment nut/scew(s) for the switch to the bracket.
If you want to send me your orig. switch, I could come up with a key for you.
1 Offline
Thanks guys for the help, I can get one local for $20, wish I could find my stash of keys and I could get one for $2 at Wal-Mart
Two clutch head screws hold the ears of the switch on. Disconnect the battery ground! Loosen the 2 screws somewhat and turn the switch counterclockwise a bit and pull it out.
