0 members (),
97
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | My 63, 292 doesn't seem to be getting much oil to the rockers. I reved the engine up porbably about 2500 RPM and held it there for about 3-4 minutes. I noticed that the headers particularly on 5 and 6 were cherry red from heat. I never noticed this before, is this normal?
Larry 68 C20 327 daily driver 63 C20 292 Camper truck 65 C10 ? Custom Cab AC,PB,PS,$flasher - Long term Project
I don't own a vehicle that isn't old enough to drink. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | Red hot header runners are an indication of running lean on those cylinders. Do you have an O2 sensor that you can check your mixture with? | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | I don't have an O2 sensor. I richened up the Monojet as part of this tuneup(?). This is a used 292 I put in till I can another rebuilt. The intake and exhaust are off the 292 I had been running for several years. This is the first time I've ever held the RPMs up while watching the motor. I'm hoping it is normal for the headers to heat up cherry red like this. 4 and 5 do seem to redder that 2,3 or 6. The fan cools off 1,2,3, but 6. I don't know.
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: Oct 2001 Posts: 130 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 130 | since the 5and 6 cylinders are fed by the same intake runner, maybe there is a vacuum leak at the intake manifold gasket at the head, causing the 5 and 6 to run lean.hope this helps. good luck.
our garage is a non-profit organization
| | | | | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The lack of oil to the rockers is a separate issue, usually due to plugged lifters.
Check for the vacuum leak by squirting around the intake with a can of carb cleaner. If the engine speeds up, you've found the leak.
Fred 52 3600 69 C-10
| | | | | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | You may also want to check your timing--it the timing is retarded the engine will have to burn more fuel to produce the desired amount of power. I have '70 Chevy Impala that the P.O. set the timing with the vacuum advance hooked up. It just never seemed to run right--I even rebuilt the carb thinking there was a passage plugged up somewhere limiting the fuel available. I ended up checking the timing on a whim and was VERY surprised to find the timing (with vacuum advance UNHOOKED) to be 3 degrees AFTER top dead center. I set the timing to 8 degrees BTDC, and reconnected the vacuum advance. I was then able to set the idle mixture and speed properly and let me tell you that car runs MUCH better--LOTS more power and much easier on fuel. I also used to tighten the exhaust pipe donuts at the manifolds (ram horns) every month and I couln't figure out why they kept getting loose. After the timing was set correctly, the donuts have not leaked since--and that was 4 months ago. My guess is that the manifolds were getting VERY hot, which was deteriorating the donuts.
Good luck, hope this long winded answer gives you some ideas.
Now I'll have to take the Impala back down to Fred T's neighborhood and show my cousin's friends how a properly tuned small block in a beat up brown Impala will really run. | | |
