3 members (k2handyman, Youngin' Tut 59, 78buckshot), 74 guests, and 3 robots.
Topics128,030
Posts1,055,418
Members48,422
Page 2 of 2 1 2
Sir Searchalot
Sir Searchalot
Maybe you can bolt a piece of angle on top of the frame rail and attach top box bolt(s) to it. Taller than the triangle piece. I did that sort of thing on a DIY install. Don't use the little triangle. Take a close look at the CPP kit. Copy that somewhat. Switch the mind set, move to copy the CPP parts that make sense.
Yup. I agree. I think the little triangle will be my new paperweight. The measurement from CPP kit really puts the box in a much better location after just a quick mock up. I think I’ll weld a bracket on though rather than bolt but will see how it goes. Darn POl.
1950 Chevy 3100
Jason
1950 3100
Sir Searchalot
Sir Searchalot
Check out post 1363433. That is the DIY method I used on a TF in a different circumstance, but worth a look.
I am more concerned about the extreme lean of the steering box.
Sir Searchalot
Sir Searchalot
Lean? as in? angle upwards? A particular pic here or in general?
Page 2 of 2 1 2
