| | | Forums66 Topics128,059 Posts1,055,825 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2018 Posts: 31 'Bolter | | 'Bolter Joined: May 2018 Posts: 31 | The existing metal/felt window channel (I believe it to be original) only runs to the top of the window on my 38 truck. At the radius of the window and across the top, the channel appears to become solid felt. I need to replace the channel but all I see for replacement material is the flexible steel/fuzzy channel. Should I just us that material in a continuous run up the back,over the top, and down the front? | | | | | Joined: Jan 2018 Posts: 298 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 298 | I used one continues piece on my 37 that I just installed. Worked great , just had to do a little forming on the corners. Ordered it from Chevs of the 40's
1937 GC
| | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | I also used the one piece " fuzzy channel " up, over, and down. Let it extend into the door a bit as well. As I recall, there are tabs inside the door to hold it. | | | | | Joined: May 2018 Posts: 31 'Bolter | | 'Bolter Joined: May 2018 Posts: 31 | | | |
