Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (1955 1 Series, farmallb, baldeagle, Dennys28, cmayna), 63 guests, and 3 robots.
Topics128,004
Posts1,055,265
Members48,418
#1294046 01/08/2019 5:02 PM
Looking at a set of brand new insert rod bearings that are for a 235' 6 cylinder on the box with no numbers stamped or written anywhere. What thickness would the insert be if it was standered? I know its cold outside, so don't make a special trip to go out to your shop and find one to mike....... Thank you
ol' 55 #1294085 01/09/2019 1:22 AM
According to the Federal-Mogul Shop Specifications Manual:
Standard shaft size: 2.312"
Connecting rod bore size: 2.437"
A little math tells me that a standard bearing will have a shell thickness of .0625"
.010" undersize: 0.0675"
.020" undersize: 0.0725"
.030" undersize: 0.0775"
These dimensions will vary slightly according to how much oil clearance is built into the bearing shells. If they don't have an undersize marked, they're probably standard size. To get an accurate measurement of the actual thickness you'll need a ball-anvil micrometer, AKA "tubing micrometer". You can get a pretty accurate SWAG with the tapered tip jaws of of a dial caliper.
Edit: These dimensions are for the 54-62 full pressure engine. Babbit-rod conversion bearings will have a different outside diameter and width.
ol' 55 #1294205 01/10/2019 3:53 AM
Jerry nailed it but I would bolt one up to a dry crankshaft (no oil) and torque it down with a strip of .001 to 003 plastigauge. If the flattened gauge measures .001 to .0025 the bearing is right for the crank pin.
Evan
ol' 55 #1294207 01/10/2019 4:12 AM
That assumes he's got a crankshaft and a rod handy. It seems he's trying to identify a set of unmarked bearings by themselves.
ol' 55 #1294449 01/11/2019 9:41 PM
Yeah well like Hotrod said if I had an extra crank I would perform a little inside /outside measuring.. I'll just hang onto them? Thank you......
