| | | Forums66 Topics128,172 Posts1,057,035 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2017 Posts: 214 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 214 | I’ve used the search feature and most people seem to be in favour, but a few aren’t. Mostly because it’s still not an overdrive transmission. We’re looking to convert ours to a floor shift - 4 or 5 speed. T5s seem to be getting hard to come by in our area, but a Saginaw would be easy to source and we are content to keep the torque tube setup and no overdrive for now. I know it could possibly take awhile to get the kit from Patrick’s. That’s fine, we just want to start rounding up what we’ll need and maybe convert in the fall. Is there anything we’ve missed, any reason to not do the conversion? We know the Saginaw and T5 can’t handle high HP and we’re not looking for a fast street rod, we’re keeping the 235 for awhile.
Thank you,
1953 Canadian GMC 9314 w/ (factory) Chevy 235
| | | | | Joined: Jan 2016 Posts: 36 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 36 | Patrick's is out of business, I'm going the 4 speed route and acquired my 2 groove Saginaw a couple of days a go. I doubt that I will miss having an overdrive after replacing my rear end with a 14 bolt 3.73. I would definitely ditch the torque tube, rather than spending more $$ to keep it with the new trans.
1950 GMC 250 Pickup 1965 Mustang Convertible 1972 K5 Blazer 1973 Buick Centurion 455 Convertible
| | | | | Joined: Jan 2016 Posts: 36 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 36 | Does anyone have any Shifter recommendations for the Saginaw 4 Speed?
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I have a Saginaw with Hurst shifter that I got from Patrick's. I ran it for a couple of years and it worked very well. Shifts really solid. I currently have a T5 and like that too. The T5 shifting is less effort than the Saginaw. I prefer the feel of the Saginaw shifting.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Oct 2017 Posts: 214 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 214 | I have a Saginaw with Hurst shifter that I got from Patrick's. I ran it for a couple of years and it worked very well. Shifts really solid. I currently have a T5 and like that too. The T5 shifting is less effort than the Saginaw. I prefer the feel of the Saginaw shifting.
Dennis Do you have the saginaw still installed somewhere or sitting on a shelf?
| | | | | Joined: Oct 2017 Posts: 214 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 214 | Patrick's is out of business, I'm going the 4 speed route and acquired my 2 groove Saginaw a couple of days a go. I doubt that I will miss having an overdrive after replacing my rear end with a 14 bolt 3.73. I would definitely ditch the torque tube, rather than spending more $$ to keep it with the new trans. At some point we'll likely go with an open rear end, just not now. I have a line on an open third member.
| | | | | Joined: Mar 2010 Posts: 843 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 843 | "Does anyone have any Shifter recommendations for the Saginaw 4 Speed?"
Buckkoo,
The OEM 4-speed Saginaw in my son's 1978 El Camino had a factory shifter that worked fine. There were no problems at all with it.
Ray
| | | | | Joined: Jan 2016 Posts: 36 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 36 | I believe the issue is not quiet so much the shifter as it is the linkages. If you look at a picture of the kit Patrick's sold you will notice that the linkages are really short compared to those you typically see.
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Lindsey, it is on the shelf. I don't think I will be using it as I'm happy with the T5 I'm now running. Dennis
40 Chevy 1/2 ton
| | | | | Joined: Oct 2017 Posts: 214 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 214 | I'm not sure if you'd be willing to ship to Canada, but if Patrick really is out of business, and I can't find a T5 I would be interested.
| | | | | Joined: Jan 2016 Posts: 36 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 36 | Separate thread, but sounds like Patrick's is DOA, hopefully they will resurface, but folks that have been by the store in Meza, AZ say the landlord has taken possession of the site.
I just used Fastenal 3PL to ship a 14 bolt rear end from south Florida to North Carolina and the cost was very reasonable. You can go to their site and get a quote in 1 day, not sure about the Canadian twist, but they are very easy to work with.
Dennis, if you'd be up for it, could you:
1) Trace the mounting bracket for the Saginaw to Hurst Shifter and upload 2) Take a picture of the shifter mounted to the Saginaw 3) Measure the 3 shift rods and post lengths I know this might be a PIA, but it would be a big help to those of us making this transmission swap. Unfortunately things happen, all to frequently, to some the folks that provide these niche parts.
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Someone can correct me, but I think it is just a Hurst shifter. I don't think he had it special manufactured. Dennis
40 Chevy 1/2 ton
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I also checked Fastenal - there is not one nearby. | | | | | Joined: Jan 2016 Posts: 36 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 36 | Linkage Rods and mounting plate are definitely unique. Hurst shifter is off the shelf.
| | | | | Joined: Oct 2017 Posts: 214 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 214 | Someone can correct me, but I think it is just a Hurst shifter. I don't think he had it special manufactured. Dennis I’m not as interested in the shifter as I am the rest of the kit to retain the torque tube rear end for now.
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Oh, we are talking two different things then. I misunderstood. I thought you were talking about the shifting mechanism for the Saginaw. I don't have anything for the torque tube rear end. I've got open tube. Dennis
40 Chevy 1/2 ton
| | | | | Joined: Oct 2017 Posts: 214 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 214 | Oh, we are talking two different things then. I misunderstood. I thought you were talking about the shifting mechanism for the Saginaw. I don't have anything for the torque tube rear end. I've got open tube. Dennis Yeah the Patrick’s kit has two parts, the shifter setup and also the parts to convert the Saginaw to retain your torque tube setup if you want. Which we do for the time being.
| | | | | Joined: Oct 2017 Posts: 214 'Bolter | | 'Bolter Joined: Oct 2017 Posts: 214 | I might still be interested if you were willing to ship.
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | This conversation has morphed into a parts for sale/free/barter thread and should be taken to PM’s. Such activity is prohibited in the garage forums. Thank you.
| | | | | Joined: Jan 2016 Posts: 36 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 36 | Agreed, however my request to:
is entirely within the mission of these forums.
So if anyone out there can share this technical data, I am sure it will be appreciated by many.
