| | | Forums66 Topics128,156 Posts1,057,017 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 36 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 36 | I'm rebuilding my drive train from the water pump to the rear differential after spinning a bearing. The 260 is headed to Charlotte for some hot rodding, a 14 bolt rear end is in transit from Florida and will be getting a disc brake conversion. Not sure if I'll go with 70 C20 calipers or 77 Eldorado calipers as the later are scarce as hen's teeth.
Scored the missing component this weekend, a freshly rebuilt Saginaw 2 groove, 4 speed. Now with Patrick's gone, I need to figure out my shifter options. I'd like to go back with a floor shifter similar to stock.
Looks like tracking done someone with the mounting plate and shortened shift linkages is one option.
Any ideas?
1950 GMC 250 Pickup 1965 Mustang Convertible 1972 K5 Blazer 1973 Buick Centurion 455 Convertible
