7 members (Sjm, Gdads51, JoergK., Hotrod Lincoln, KEVINSKI, cmayna, 1 invisible), 88 guests, and 1 robot.
Topics128,260
Posts1,058,313
Members48,485
The task today was to grease my '58 chassis points as defined in the 'Chevrolet Truck Manual' and owners manual. I ran out of grease before starting and since I needed to buy some, I thought 'what is the best type and brand of grease to use as chassis grease'? The manuals do not give a specification for this grease. Probably what I have been using has been ok since nothing has failed. Am wondering what others use and suggest to use for chassis lube.
I have installed a LockNLube grease coupler (https://locknlube.com/) on my grease gun, this makes greasing a whole lot easier
1958 Chevrolet 3600 NAPCO 4x4 Apache
"Calvin"
H Online: Content
Just about any "multi-purpose" chassis grease should be sufficient to lube stuff like tie rods, king pins, spring shackles, etc. Just don't use the same stuff for wheel bearings- - - -it's not temperature rated to be used around brakes. If a grease fitting isn't clogged up with solidified grease from decades of not getting lubed, that lock-on tip shouldn't be necessary. If you force a bunch of old grease and the road dirt that's mixed with it into the parts that need to be lubed, are you really doing yourself any favors?
Jerry, I always wipe the zerks off before pairing the lockNlube to them, not so much to force the grease in, but keeping the gun end paired to the zerk sometimes is an issue with a long-handled gun (not pistol-grip) that takes 2 hands to operate. Everything underneath on this truck is pretty clean and new, to my advantage.
This grease looks to be better for heavy duty and high temp applications. https://www.valvoline.com/our-products/heavy-duty/cerulean-grease
"Calvin"
H Online: Content
Back when I was teaching auto mechanics, we had a fairly long series of lessons on lubricants in general, and grease in particular. All "grease" is made up of at least two components, plain old lubricating oil, either mineral based or synthetic, and "soap" which gives it enough stiffness to stay put. Some soaps aren't compatible with others, something that can pose a problem with wheel bearings in particular. Since it's not practical to clean all the old grease out of things like tie rods, ball joints, etc. there might be a situation where radically different base greases might not play well together. Other than that, if it's good and slippery and stays put without leaking out, no problem!
