6 members (Peggy M, J Lucas, 78buckshot, Uncles51, Youngin' Tut 59, 1 invisible), 84 guests, and 4 robots.
Topics128,174
Posts1,057,048
Members48,458
#1293257 01/02/2019 4:27 PM
My 1949, 3100, 1/2 ton with 6 wheel studs is leaking oil at the rear brake attachments. Looking at the service manual, it appears that you have to remove the whole rear differential/axle/driveshaft assembly from the truck to install new seals. Is this what you have found? I am asking because if there is an easier way, I'd like to know!
Best regards,
Joe
'49 3100 "Sweet Caroline" because the truck has fabulous curves .... like Caroline!
Hello, Joe,
What year manual, and what page (I'll look after I post this)?
You can remove the rear wheels, and then open the back of the rear end to allow removal of the axle shafts.
Each seal can then be pulled/pried out.
If there are no seal-wear marks/grooves in/on the axle shafts, you can just replace the seals.
If there are grooves, you can install a "speedi-sleeve"for each side, available on-line and from good parts shops.
Ask here for sources, if needed.
I'd suggest replacing the rear axle bearings during this operation.
My experience has been: after replacing old bearings, the rear end/axles noise is reduced.
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0403.htm
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0404.htm
Removing the old bearing "race" might need a tool.
Maybe other members will confirm and post advice on this?
(I have only done this on three trucks - all 3100 48-54)
To Tclederman: Thank you, what a relief!
