0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2017 Posts: 13 New Guy | | New Guy Joined: Jul 2017 Posts: 13 | I have a 56 GMC 100 and am trying to remove the temperature sending unit atop the engine. It is brass and I've tried to apply penetrating oil a couple of times now and still cannot get this thing to budge. Any suggestions on how to safely remove this unit without breaking it? | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | A little heat from a Propane torch, followed by tapping the wrench flats with a hammer and a blunt punch will usually get things moving. PB Blaster is a good penetrant- - - -KROIL is much better. Heat- - -tap- - - -soak- - - -repeat. Jerry
| | | | | Joined: Dec 2012 Posts: 11 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 11 | And it goes without saying to use a deep six-point socket. | | | | | Joined: Jul 2017 Posts: 13 New Guy | | New Guy Joined: Jul 2017 Posts: 13 | Sounds like good advice. Thank you guys - I'll give it a try. | | |
