0 members (), 191 guests, and 2 robots.
Topics128,089
Posts1,056,141
Members48,436
I have a 56 GMC 100 and am trying to remove the temperature sending unit atop the engine. It is brass and I've tried to apply penetrating oil a couple of times now and still cannot get this thing to budge. Any suggestions on how to safely remove this unit without breaking it?
A little heat from a Propane torch, followed by tapping the wrench flats with a hammer and a blunt punch will usually get things moving. PB Blaster is a good penetrant- - - -KROIL is much better. Heat- - -tap- - - -soak- - - -repeat.
And it goes without saying to use a deep six-point socket.
Sounds like good advice. Thank you guys - I'll give it a try.
