1 members (Hotrod Lincoln), 97 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
I have a 56 GMC 100 which I am rewiring and have a question for all about an abbreviation found on the wire for the temperature sending unit mounted on the engine block. The schematic shows "18 F - (H.W.)" for the wire going from the engine mounted sending unit to the temperature gauge.
Does anyone have an idea what "H.W." stands for? It is the only wire on the schematic with that abbreviation.
3B Offline
Hy Chuck M, I assume you are installing an aftermarket wiring harness, I'll take a wild [censored] guess, Hot Water, or Hot Wire, or Heat Wire???
Sir Searchalot
Sir Searchalot
18 F is 18 gauge wire, F= Dark Green. The 18-F is shown on the official 55-59 GMC manual schematic. H.W. is not.
What schematic are you looking at?
If it is a aftermarket harness, assume it is harness company nomenclature. Call them if you need to know. Maybe if it runs across the motor, they want it "Heat Wrapped". Any wire near exhaust or motor, should be protected by raising it up, reroute or loom. PVC goes to 125 F and GXL goes to 250 F.
Insomniac
Insomniac
Drawings should have a table explaining what any abbreviations used actually mean. Or there should be specifications that accompany the drawing to provide the explanation.
My guess is that it refers to the wire insulation; HW means heavy wall? Hot, shaky engine is a nasty place for a small 18 ga wire. Extra insulation would be a good idea, it seems to me.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Sir Searchalot
Sir Searchalot
New guy went south.
Chuck M
From South Florida
Joined Fri Jul 14 2017 02:20 PM
Last Seen Tue Jan 01 2019 08:56 PM
Total Posts 8 (New Guy) [not so new; just not a frequent visitor]
Sir Searchalot
Sir Searchalot
"New Guy" went south.
New guy did not go south - just had my head under the hood and in the dashboard for a while!
The schematic I am referring to is that which is in the GMC shop manual for my vehicle - it most definitely lists 'HW' - perhaps the shop manual is different than the "official 55-59 GMC manual schematic" someone referred to.
I'm not using an aftermarket harness but trying to do things the way the factory set it up with respect to color, gauge, etc. I've checked the manual and there is no index for abbreviations so I'm thinking this was a 'rogue' draftsman or engineer.
Any way, thank you for the input.
Chuck, no problem with your short vacations. You must understand the folks most likely to answer your question check the “Bolt” every day and some more than once. It’s hard for them to understand the several days absence. The fact you are working on your truck is as good an excuse as anyone could have. I don’t think we have an answer for your HW question. Don’t give up on us, we usually have all the answers and then some whether you want them or not. grin
Sir Searchalot
Sir Searchalot
I've seen draftsmen sneak in their initials on drawings. Looks like old Howard Witherstinker got his in there.
Or if you want to be more politically corrupt, we call them Drafters now.
