| | | Forums66 Topics128,023 Posts1,055,367 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 547 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 547 | It's been since 2013 that my 1958 Apache was driven. I'm finally getting the engine back in and hooking everything up. Where do ya'll have the battery ground running to? I think I use to have it grounded next to the Ign Coil, but I sealed those bolts to keep oil from leaking out.
58' 3200 235 3-speed/OD
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | My 56 has a cable from the neg side of the battery to a captured nut on the lower right side of the firewall. From that connection it has another cable to a bell housing mount bolt. I believe that to be similar to the factory connections. Use star washers at the connection points. Grounds do not work well with new paint. Fred
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | There should be a threaded ground boss on the firewall just above the battery tray shelf. That's where the battery ground goes. Then below that, where Fred says, is another threaded ground boss. A braided cable goes from there to a starter bolt. They always use a starter bolt for motor ground because it's near main positive cable input at starter stud. A braided cable from one of those places to the frame is also necessary. None of this is cast in concrete (just in the FAM), but battery neg-motor-body-frame must have continuity.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2004 Posts: 29,746 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,746 | Unless you're building a rig to compete in concours-type car shows, run a #0 or larger cable from the battery negative post to one of the bellhousing or starter attaching bolts, and use smaller-diameter ground leads to the body and frame from the engine. A ground wire from the bed to the frame is another important one if you want tail lights and turn signals to work right. Jerry
