0 members (), 50 guests, and 6 robots.
Topics128,014
Posts1,055,327
Members48,419
#129287 11/26/2002 4:36 AM
I'm running a standard - what vehile would make a good donor for a steering column? (I will also be running a standard tranny).
I've got an 89 blazer in my driveway, but it's got the shifter on the steering column.
May the force be with you - SoloWookie
solowookie.com
#129288 11/26/2002 5:31 AM
Most any GM collapsible column from a floor-shift car will work. Some vans had nice ones too. They only made 2 or 3 different lengths, should be easy to get one!
Im using a 84 Impala column in my 50 Burb. This gives me hi-low beam switch, wipers, turn signals and column shift!
If your one of those guys like me who pull themselves in with the steering wheel, try to pass on the tilt wheel! (how often do you adjust it anyway)?
John Kennedy
1950 Suburban street rod
Pics in the Gallery.......
new site up!
http://home.joimail.com/~kennedyjp/
#129289 11/26/2002 6:09 AM
thank's for the info... I didn't realize I had this much flexibility.
solowookie.com
#129290 11/28/2002 8:20 AM
Jeep CJ's of the AMC era used GM steering columns and were usually manual shift. There are several companies marketing new columns in the GM pattern. That may be more money than you want to spend, though. You can also use the original if you cut it and fabricate shafts for it, as long as you don't mind it being an impaler.
Paint & Body Shop moderator
#129291 11/28/2002 7:22 PM
what do you mean by being in impaler??? all these are colapsable steering columns. I think I'm going to try this steering shaft out of this wrecked k5, and I'll do a touch of metal work to get rid of that pieces that holds the shifter.
at least it will let me judge length first.
solowookie.com
#129292 11/28/2002 9:26 PM
Anonymous
Unregistered
Anonymous
Unregistered
Solo, I sawed my auto shifter off and smoothed it, filled the hole with bondo and painted, no one could tell when it was done and only took an afternoon to do.
#129293 11/30/2002 10:04 AM
There are ChevyGMC vans that have columns that have no shifter or key switch on them.they just have the turn signal switch handle.Nice and clean cool
