| | | Forums66 Topics128,184 Posts1,057,196 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 51 | I have recently been given an offenhauser intake and fenton headers. I hope to install them on my Chevy 261 which is bored 0.030 over with a stock cam. I do have a set of Rochester Model Bs that I plan on installing on the intake. I am assuming that I will need to rejet the carbs and possibly install lighter power valve springs. The main jets in the carbs are currently 63s; I am assuming that the springs are stock. I am not sure what size main jets and power valve springs I should use. Anybody got any recommendations?
In addition, I do plan on providing heat to the offenhauser. I am still not sure if I will be using water or exhaust heat. It seems as if water heat would be less destructive to the offenhauser intake since I am afraid that the corrosive exhaust gases would eat it up. I have the threads concerning manifold heat. I don't think that the corrosive gas issue has been addressed. I apologize if I missed it.
Thanks in advance for any advice you can offer.
Jon | | | | | Joined: Sep 2004 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 51 | I forgot to mention that the intake is a dual carb intake.
Jon | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | you can get a predrilled carb heat plate from langdons stovebolt, i plan to get one for my conversion i did this summer. i can't believe the differance the fentons with dual exhaust made to my power, nothing spectacular but enough more so i don't have to change gear rations just yet. i have a 54 with 235 with dual carbs, the carbs idid 5 years ago and it still couldn't hardly pull it self. 273 nova rearend is part of the problem. ron good luck it was worth it to me.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Sep 2004 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 51 | WE b Old: Thanks for the reply. I glad to hear you were happy with the results. I hope to get similar results from the 54 261. | | | | | Joined: Feb 2000 Posts: 364 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 364 | jon..I also installed the same set-up you mentionned on a '58 235. Couple of "lessons learned"...avoid Rochesters if possible...Langdon's Stovebolt sells properly sized Carters for that set up...I started out with the Rochesters and suffered with them for a couple of years (leaking/loading up/basically untuneable)I switched to Carters and all my problems were solved. (Carters are not expensive!). The manifold heater(water) is a nice addition and easy to install. Good luck. | | | | | Joined: Sep 2004 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 51 | Thanks for the advice Steve. I have sent Tom Langdon a message regarding my set-up. I will ask him about the Carters when he replies. Did you use Carter YHs or W-1s? | | |
