2 members (Nick in Manitou, 1 invisible), 116 guests, and 3 robots.
Topics128,090
Posts1,056,369
Members48,442
#1289512 12/01/2018 2:44 PM
What is the safest way to support the frame while removing the rear axle? I hope to disconnect all brake lines, etc and remove u-bolts from springs. My concern is how high I will need to get it to take all weight off of the axle.
Any advice appreciated.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
I vote for heavy duty jack stands.🛠
Crusing in the Passing Lane
No concrete blocks!
Ed
What's wrong with balsa wood blocks? Just kiddin' Yes for jack stands.
Craig
Heavy duty jack stands with pins (rather than the type with teeth). Or a properly built wood block stand.
Another quality post.
Real Trucks Rattle
When I'm working on really heavy stuff like my tractor or any kind of tracked vehicle, I use crisscrossed layers of timber similar to railroad ties for support. They give a bigger footprint and better weight distribution than stands. a stovebolt sized truck should be plenty safe with jack stands, but the wider the base and the heavier the weight rating, the better.
Exactly what HRL said. Especially if you are yanking stuff around under there.
Real Trucks Rattle
Sir Searchalot
Sir Searchalot
Of course, block front wheels and remove driveshaft.
Remove brake lines and ebrake cables. Jack up the rear by placing jack on the differential housing. Lift until tires clear floor. Place frame on jack stands. Take off rear tires. Lower diff near floor until any spring tension is gone. Undo Ubolts almost all the way, let diff down more till ubolts are wiggle free, unbolt them completely and roll diff away. Undo ubolts in steps and let diff down a little at a time to gauge spring looseness until ubolts are free.
Don't be under the diff. Do everything slowly and be sure it makes sense. This is a general procedure you can modify anywhere you wish.
(A transmission jack would be nice to have).
Don't know the plan but if you need to move the diff around the shop or yard, put the tires back on.
Thanks everybody!
1957 GMC 150
