0 members (), 123 guests, and 8 robots.
Topics128,186
Posts1,057,211
Members48,465
I have recently been given an offenhauser intake and fenton headers. I hope to install them on my Chevy 261 which is bored 0.030 over with a stock cam. I do have a set of Rochester Model Bs that I plan on installing on the intake. I am assuming that I will need to rejet the carbs and possibly install lighter power valve springs. The main jets in the carbs are currently 63s; I am assuming that the springs are stock. I am not sure what size main jets and power valve springs I should use. Anybody got any recommendations?
In addition, I do plan on providing heat to the offenhauser. I am still not sure if I will be using water or exhaust heat. It seems as if water heat would be less destructive to the offenhauser intake since I am afraid that the corrosive exhaust gases would eat it up. I have the threads concerning manifold heat. I don't think that the corrosive gas issue has been addressed. I apologize if I missed it.
Thanks in advance for any advice you can offer.
Jon
I forgot to mention that the intake is a dual carb intake.
Jon
you can get a predrilled carb heat plate from langdons stovebolt, i plan to get one for my conversion i did this summer. i can't believe the differance the fentons with dual exhaust made to my power, nothing spectacular but enough more so i don't have to change gear rations just yet. i have a 54 with 235 with dual carbs, the carbs idid 5 years ago and it still couldn't hardly pull it self. 273 nova rearend is part of the problem. ron good luck it was worth it to me.
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
WE b Old:
Thanks for the reply. I glad to hear you were happy with the results. I hope to get similar results from the 54 261.
jon..I also installed the same set-up you mentionned on a '58 235. Couple of "lessons learned"...avoid Rochesters if possible...Langdon's Stovebolt sells properly sized Carters for that set up...I started out with the Rochesters and suffered with them for a couple of years (leaking/loading up/basically untuneable)I switched to Carters and all my problems were solved. (Carters are not expensive!).
The manifold heater(water) is a nice addition and easy to install.
Good luck.
Steve G.
1942 Chevrolet 1/2-Ton Pickup Truck
Thanks for the advice Steve. I have sent Tom Langdon a message regarding my set-up. I will ask him about the Carters when he replies. Did you use Carter YHs or W-1s?
