3 members (Stewart2, 55shaker, 1 invisible),
145
Mod | | | Forums66 Topics128,165 Posts1,057,010 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | I'm backdating the gauges on my '48 GMC 1 Ton and need to change out the oil fitting at the block that supplies oil to the gauge as well as to the oil filter. There is a 90* brass fitting that threads into the block with one outlet feeding the gauge and the other outlet going to the oil filter. The oil filter connection will have to be removed first and I'm wondering how big a mess I'll be making when it's disconnected. I'm guessing the outlet to the gauge would only leak out under pressure but I could easily be wrong. What should I expect? Thanks, Jim
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | All you can expect will be a little drip unless you or someone starts the engine. Then you will have a big mess. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Put a couple of rags under the fitting to catch the drips. There won't be much, but the line going to the oil filter will dribble enough to make a mess unless you raise the end of the line above the level of the filter housing. If you pull the top off the filter canister and remove the element first, there will be a lot less mess to deal with. Jerry
| | | | | Joined: Feb 2013 Posts: 250 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 250 | Hahaha George, even I know better than that! And thanks, Jerry, I didn't think of removing the element but I will now. I'm always learning something new on Stovebolt. | | |
