0 members (), 52 guests, and 0 robots.
Topics128,050
Posts1,055,643
#129243 11/19/2002 2:03 PM
Has anyone installed an S10 rear end on a 50 Chevy chassis? You can get one in a 6 or 5 bolt. I was wondering if the width was OK. I know that the 50 Chevy truck rear end is 60" and the S10 is 58".
http://www.50chevy.freeservers.com/Suspension_Widths.html#Suspension
#129244 11/19/2002 4:38 PM
Richie,
I had a '56 Chevy pass car rear (57" wide as I recall) under my '49 at one time and I had to put wheel spacers (1" per side) to keep the tires from rubbing on the outside of the bed with any kind of a load. I was using the '56 pass car rims with this rear end.
I put a '69 pass 12-bolt under it after that (60.5" wide) and never had any problems with tires rubbing. I had 15x7 rims from an S-10 with 235-70 tires on it the last few years before I tore it down for the rebuild I'm currently doing. Even heavily loaded, the tires cleared everything alright.
I did mount the shocks inboard of the frame when I changed the rear end so I don't know if they're an issue or not.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
#129245 11/20/2002 3:56 AM
just so's ya know, the 2wd rears are about 4" narrower than the 4wd's
i miss obscene phone calls...
