1 members (ronsway),
185
Mod | | | Forums66 Topics128,167 Posts1,057,019 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | We have a 1958 Apache 3100 that we are having restored as close to original as we can get (except for the front disc brakes). The restoration shop ordered 15" diameter X 8" wide slotted rims. They wanted to 'fill' the wheel wells thinking the factory supplied wheels and tires would look too narrow. This truck will not be a 'Trailer Queen' or a daily Driver, but we will drive it. I want it to function well and my wife and I to be able to steer it. We did not opt for power steering.
What I would like to know is first, were the original factory wheels/rims slotted or not (when I bought this truck it had some funky after market white spoke wheels) and second what is a common size wheel and tire size that most folks are putting on their restored, no power steering, trucks '55 thru '59?
John | | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | I have Coker P205/75R15 tires on mine. they don't quite "fill" the wheel wells but they work well and i dont have power steering either | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | What about your wheels? Are they solid rims or do the rims have slots in them? | | | | | Joined: Dec 2008 Posts: 901 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 901 | I'm running 15"x6" wheels with 225/75/15 tires. The steel wheels came off of a late 70's 4X4 1/2 ton Chevy truck. They have a little less back spacing, which makes them stick out a little farther, and helps to fill the wheel well.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | original 15" wheels with the tallest skinney radials you can stand will handle and steer fine, I ran 700r15LT Yokohamas on my 58, looked fine find pics of original wheels and caps here - the later wheels Brian mentions work fine but won't have the clips for correct hubcaps . . . the 8" wide wheels will be a strain on your front wheel bearings and spindles, especially with fat enuff tires to fit the width Bill | | | | | Joined: May 2006 Posts: 934 'Bolter | | 'Bolter Joined: May 2006 Posts: 934 | I had the same truck and the previous owner put wider wheels with the stock straight axle. Steering and wander was problematic. Installed new king pins, put on a steering damper to help the steering as a last resort. The steering still wandered and lurched with road crown after front end alignment to specifications. Narrower tires helped a lot more by keeping with what GM engineers designed. Put stock rims back on with radial tires.
| | | | | Joined: Jun 2006 Posts: 693 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 693 | What about your wheels? Are they solid rims or do the rims have slots in them? my wheels look like the ones in Bill's link for the 57-60 trucks | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | Thanks to all so far for your help. Hope this will 'steer' us in the right direction.
John | | | | | Joined: Nov 2000 Posts: 1,971 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,971 | The original wheels were probably 15 X 5.5. As others stated; tall skinny tires will steer easier.
Professional Novice
| | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Yup, the 6.70x15 was the "base" tire...diameter was about 27" if I remember correctly. Mike B  | | |
