3 members (2-Ton, Mike B, 1 invisible),
69
Mod | | | Forums66 Topics128,030 Posts1,055,419 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12921 03/20/2002 3:08 PM | Joined: Jan 2002 Posts: 18 Member | | Member Joined: Jan 2002 Posts: 18 | I just rebuilt my 235 in my 55 Chevy car and I forgot how the throttle return spring mounts. Can someone help me. Any pictures would be great too. Thanks. | | |
#12922 03/21/2002 5:56 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | On trucks (cars are the same, iirc) there is a clip welded on the carb linkage just above the pivot lever on the side of the block. The spring hooks in there, and goes straight down, hooking into a hole through the block in the oil pan flange mating surface.
Fred 52 3600 69 C-10
