1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#12917 04/13/2005 4:21 AM | Joined: Jul 2004 Posts: 46 Junior Member | | Junior Member Joined: Jul 2004 Posts: 46 | Does anyone know where to buy a good rebuild kit? Im hoping that rebuilding the carburetor will improve the way the truck drives alot. The rebuild should be very cheap and should hold me off until i put a new motor in. | | |
#12918 04/13/2005 6:17 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | | | |
#12919 04/13/2005 6:37 AM | Joined: Aug 2003 Posts: 31 Junior Member | | Junior Member Joined: Aug 2003 Posts: 31 | I was having troubles with my old rochester. Rebuilt it and was still having problems (worn out at the throttle plate pivot points). I am very careful when rebuilding and just couldn't get it to stay adjusted. Ended up replacing it with a unit from the local parts store for about $75. Best investment I made for a smooth engine, better starts and more mpg. Don't like to throw money at a problem but it was surprisingly cheap for a carb and it did the trick.
I feel like I'm diagonally parked in a parallel universe.
#12920 04/13/2005 10:12 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Conceived was lucky. About half -the reman carbs don,t work right. I would try rebuilding it first. You can get a kit from Carquest or Napa for about $20 or less. It,s true sometimes you just can,t get it right & have to resort to a reman. Don,t turn the old one in till the job is done & working right.  They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
