1 members (‘37ChevyPU), 86 guests, and 3 robots.
Topics128,211
Posts1,057,476
Members48,473
Shopping for rubber brake hose for my 1938 1.5 ton and only finding parts listed for smaller trucks.
I must have one peeling on inside as it pressures up and holds until I open bleeder. Where do I find big bolt brake parts, or will small truck hoses work? Thanks for any help!
Tony
Tony,
I am not certain about your particular model, but fortunately Chevrolet used a very generic brake hose that was used on a myriad of other vehicles. I believe a Wagner F-4497 or Raybestos BH-4497 will fit your truck. All three hoses are the same part number. Same hoses as on my 1941 1 1/2 ton truck.
https://www.rockauto.com/en/catalog/chevrolet,1938,truck,3.5l+217cid+l6,952872,brake+&+wheel+hub,hydraulic+hose,1792
Paul
Lots more pictures
The parts book I have shows that all Chevrolet vehicles used the same brake hose from 1936-1948 (The parts book is a 1948...). Paul is correct with the part numbers, they are readily available and have been used as recently as 1970 on new vehicles.
1935 QD 1.5 ton stake bed
1937 SD 1.5 ton stake bed
1944 MS 1.5 ton stake bed
1946 PW 2 ton stake bed
Paul and neon,
After your helpful post I got a brake hose from my local parts store for $13.00.
I disassembled the brake assembly, honed the cylinder, cleaned everything, packed bearings, adjusted shoe-to-drum and the brakes work wonderfully!
I have pictures of my 1938 1.5 ton on "big bolts" for everyone to see. Stovebolt.com is a great find! Lot of helpful enthusiasts here and I am enjoying this whole experience very much. A big thank you to all members.
Paul and Neonman...you guys rock! Thanks for fast help!
Tony
V
VEW Offline
V Offline
STOVEBOLT ROCKS!!!!
(Just had to say that smile )
~ Victor
1957 3100 - moved on
