4 members (Otto Skorzeny, Gdads51, Opelika Tom, crenwelge), 75 guests, and 1 robot.
Topics128,062
Posts1,055,851
Members48,428
#129158 05/09/2005 2:38 AM
Junior Member
Junior Member
Hello Everyone, so I just wrapped up mounting a healthy little small block chevy into my 36 chevy and now that it has alot of "Go Boy" it needs to have alot of "Whoa Boy" as of now the truck has hydraulic manual drums... but a previous owner has gotten into this poor machine and changed a bunch of stuff around... for example, when I got the truck it had a dropout positraction unit from a 57-64 chevy passenger car... it still has the solid front axle but from what I couldn't tell ya, someone cut the front axle in half and either shortened it or lengenthed it and welded it back together... the front hubs are 5 lug 4 3/4" bolt circle... does anybody have a clue where these suspension bits came from? or does anybody know how to convert to discs perhapse? HELP!! come check out pictures of the engine swap... www.mykkhannan.bravehost.com/projects.html
#129159 05/10/2005 6:56 PM
Its not possible to give a definitive answer regarding disk brakes without knowing what the spindles are...
It sounds like you have '49 to '54 Chevy car brake drums on the front. That would suggest the spindles will take one of the commonly avaiable disk brake kits for a '47-'54 pickup.
But I'm just guessing...
Take it apart and measure the spindle diameter at the inner and outer bearing surfaces. If they are the same as a '47 - '54 the next question is are the backing plate holes in the same place as the '47 - '54. If they are, the disk kit should work.
