| | | Forums66 Topics128,284 Posts1,058,523 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 33 Junior Member | | Junior Member Joined: Feb 2005 Posts: 33 | Hello Everyone, so I just wrapped up mounting a healthy little small block chevy into my 36 chevy and now that it has alot of "Go Boy" it needs to have alot of "Whoa Boy" as of now the truck has hydraulic manual drums... but a previous owner has gotten into this poor machine and changed a bunch of stuff around... for example, when I got the truck it had a dropout positraction unit from a 57-64 chevy passenger car... it still has the solid front axle but from what I couldn't tell ya, someone cut the front axle in half and either shortened it or lengenthed it and welded it back together... the front hubs are 5 lug 4 3/4" bolt circle... does anybody have a clue where these suspension bits came from? or does anybody know how to convert to discs perhapse? HELP!! come check out pictures of the engine swap... www.mykkhannan.bravehost.com/projects.html | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Its not possible to give a definitive answer regarding disk brakes without knowing what the spindles are...
It sounds like you have '49 to '54 Chevy car brake drums on the front. That would suggest the spindles will take one of the commonly avaiable disk brake kits for a '47-'54 pickup.
But I'm just guessing...
Take it apart and measure the spindle diameter at the inner and outer bearing surfaces. If they are the same as a '47 - '54 the next question is are the backing plate holes in the same place as the '47 - '54. If they are, the disk kit should work.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
