0 members (), 106 guests, and 0 robots.
Topics128,101
Posts1,056,181
Members48,436
#129145 02/07/2003 6:54 PM
Hello again. I need to get some advice. I am installing my gas tank (aftermarket product will be located behind the rear axle) and redoing my brake system. Does anyone have advice on where I should buy my brake and fuel lines and fittings to replumb my 1950 Chevy 1/2 tone truck? Thanks.
#129146 02/07/2003 7:40 PM
Local Mom&Pop auto parts store. Mine knows me real well on account of all the small bits I needed.
#129147 02/07/2003 9:02 PM
smile howziit guy!
your FLAPS...generic steel lines available in various lengths.
that, and a tubing bender will save you over $100, plus shipping costs and delay.
FWIW, buy it cheap, and bend your own. looking at costs versus % mark-up wise, it's the greatest cost-effective DIY task...or the biggest rip-off, if you buy pre-bent.
Myron
1956 chevy 3100 stepside, Pro-Street stance, mild 454 BBC/350/9"/13" M/T'S, daily driver, aka THE PINK LADY
1957 Bel-Air coupe, 500 HP blown sbc in progress, aka LANI
#129148 02/19/2003 11:29 PM
Hey man I am about to that point. What kind of tank are you useing and were did you get it? I Have been looking at the one that Brothers has which is over 500 bucks eek
Thanks!
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces
2000 GMC Serria 1500 SL 4x4
#129149 02/22/2003 5:11 AM
If buying cheap tubing and a bender was all there was to it, then there would be no question about the economics of making your own brake lines. But, brake lines are double flared. The cost of a flare tool that is correct for brake lines and will allow you to get a good double flare will just about put the economics of pre bent lines over the top. I wanted to go with stainless and the cost of the seamless stainless tubing plus a tool that would handle it was more than having them replicated by inline tube. http://www.inlinetube.com/. For $110 I got every line replicated in stainless, complete with protective springs where there had been some, mailed to my front door. And they fit. The most dificult part was remembering where all the original supports mounted up.
#129150 03/03/2003 2:14 AM
smile howziit again guys!
buying NAPA steel brake lines(cheap) and a bender really is all you need. not even a double flaring tool is needed, if you plan right.
i just finished bending the lines, for my shortened 9" **** rear end, in my '56 chevy truck. one 30" tubing, 1 20" tubing, and the t-fitting and hose that was under there(who knows WHAT the PO got it from?lol)
i doubt if they have prebent lines for my situation. maybe they can make me custom ones, if i crawled under there, and gave them the specs, including the EXACT location of my FOUR u-bolts, shock locations, length of my rear end and each axle tube, plate to plate,etc.
for the total sum of $5...and change, i had CUSTOM-BENT(by me) steel brake lines. heck, i didn't even have to cut and re-flare!
i'm not knocking prebent SS lines, if that's what you want. i'm just saying that anyone(except my PO), any amateur can get the job done, and be durn proud of his work.
if you feel guilty about the cheap fix, you can always farm out the job. the mechanic will probably factor in about 1-2 hours' labor rate, and charge you retail for the same NAPA lines. after leaving your truck for the better part of the day, he might even relate to you how hard it was, to "custom bend" the lines. that'll make you feel better, for being charged maybe $100 or so, for the rear brake lines alone.
i also upgraded to 3/8" steel NAPA fuel lines, from electric fuel pump to regulator. they were so cheap, i forget the price. since i didn't have a "union fitting" on hand, i used a 2" fuel hose, to connect the long lines.(i left the flare and the nuts on, so i could install the "union", at a later date.)
it took me longer to create this reply, than to install the fuel lines AND the brake lines.
BTW, i'm 56 years old. if the new steel lines wear out before i die, i'm looking forward to bending brake lines again!
it is as simple(and as easy) as i make it sound. cool
Myron
