0 members (),
153
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | I installed a ron francis vr4 voltage reducer to run my heater when I converted to 12 volts, it worked well for a couple of years, but the other day the heater blower was going really fast, and then the fuse blew. I now have 12 volts to the heater. While looking at what happened I noticed the ground to the reducer was kind of loose, could that have fried the reducer? I really, really don't want to remove that heater again to install a 12 volt motor, the reducer was expensive enough. | | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | I wrote a long reply and my server ate it! Use one of the GM speed control resistors that mount in the air box and pick out the right combination of connections to get the blower speed you want. Cheap, simple, and available at any FLAPS or on Ebay. Jerry
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think you are saying that you have a 6 volt heater motor and a 12 volt system. If that device was a 3 terminal regulator and the ground came loose then it would certainly malfunction. I used a 1 ohm 50 watt resistor in series with my heater when I converted to 12 volts. Most of the truck part vendors sell them. They should be mounted on some sheet metal to dissipate heat. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | A circuit with a resister will show the maximum voltage with no load on it. Just like an ign. coil. If the points are open so there is no complete circuit the voltage at the coil will be 12 volts. With the points closed it will be 7-9 volts. You may have bad motor. Run a jumper wire from the bat. to the motor wire & see if it will run. Running it on 12 volts for a few seconds won't hurt it. If the motor is good test the reducer. Make sure your reducer & the motor has good grounds. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
