0 members (), 140 guests, and 1 robot.
Topics128,080
Posts1,055,953
Members48,430
#1291317 12/16/2018 2:10 PM
Great site, need some help. On a 1954 Chevy 235 6 volt starter, can someone tell me what the side terminal on the starter switch is used for. What wire if any is connected to that terminal, and we're does that wire. This truck has been converted to a 12 volt system with an alternator. And thanks for your help.
Red53. Someone will be along shortly to tell you what the side terminal is used for.
However, I do recall this being discussed in the middle of a long thread.
If you have not stopped in to the Welcome Centre, please go there and introduce yourself.
Another quality post.
Real Trucks Rattle
That terminal is used to provide full battery voltage to the upstream (ignition switch) side of the coil during cranking. If your electrical system has been converted properly, there should be a ceramic resistor inline between the switch and the coil to drop the voltage to about 9 volts or a little more during normal running to protect the points. Because the load of the starter drops the voltage, it's necessary to bypass the resistor so there's a hot enough spark for a good cold start. Just connect a wire from the small terminal to the coil + terminal.
Edit: That switch was original equipment on 12 volt starters from mid-year 1955 and newer engines, but it's a bolt-on swap for the 6 volt starter switch which did not have (or need) the bypass terminal.
Jerry great reply thanks. Question I have a pentronix igniter in my distributor with stock 12 volt GM coil used with an external resistor, would this bypass still give me the same increase in voltage.
I'm having a crank no start problem, I do have power every were up to coil, but no spark at plug.
Read the instructions which came with your Pertronix.
You need 12 volts to the coil with the Pertronix .
You don't need to use the 3rd terminal on the starter, nor an external resister.
Another Pertronix bites the dust.
Let me send you my sincere condolences about having that Pertronix- - - - -Do you also have a good pair of hiking boots?
