3 members (cmayna, TUTS 59, 1 invisible), 146 guests, and 3 robots.
Topics128,070
Posts1,055,896
Members48,428
#1291354 12/16/2018 8:01 PM
I have a 261 that came out of my '62 C10 and while I did want to V8 swap my truck, I'm considering rebuilding my 261 and keeping it instead. My question is what automatic transmissions are there that can be easily hooked up to a 261 and where would I find them? I'm pretty inexperience with things like this. It's my first project car.
College student trying to restore grandad's 62 C10
A Powerglide for a car 235 would be a bolt-on installation, assuming you can find the right flywheel (flex plate) and the adapter ring that bolts onto the block. Powerglides have two speeds- - - -"Too low and too high!" The only other bolt-on would be the 4 speed dual range Hydramatic- - - -scarce, expensive, and difficult to adjust the throttle linkage for proper shifting. There are vendors selling adapter plates for transmissions like the Turbo 350 and 400, and the 700R4, etc. The quality of those items varies from mediocre to excellent (Translation: E$$$$PENSIVE!)
Putting a "Belly Button" V8 in place of a good-running 261 is a huge leap in the wrong direction.
