Special thanks to Jon G for the carb butterfly screw. Got the carb back together and on the truck. Adjusted the valves and set the timing. Checked the dwell and the vacuum with the truck running. Got everything set to where the vacuum was steady at 19. Truck starts and runs great in the shop. Took it for a test ride and I still have a slight miss at road speed at the higher rpms. Not as bad as it was, but still have a little miss. I'm not sure what to check next.
Darrell
