1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
#1291074 12/14/2018 4:16 PM
Just wondering what peoples thoughts are on name brands for 261 pistons. I have seen a few manufactures floating around.
Links? Brands?
H Online: Content
There are probably only a few producers of piston castings for the 261, with a lot of people doing the finish machining and putting their own name on the box. When I worked at Armstrong Robber Co. we produced 4 brands of tires, using the same molds, rubber compounds and curing times- - - -we just changed the label inserts in the molds for "different" brand names.
U
U Offline
I used L2033 in 0.080” over, from Egge out in Calif. Six pistons with pins for $288.
https://egge.com/product/detail.php?product_id=19487&unique_identifier=15898
Life is Good
Egge uses the TRW number, may be actual remaining stock or just a convenient way to identify it.
