| | | Forums66 Topics128,034 Posts1,055,547 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 385 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 385 | Just wondering what peoples thoughts are on name brands for 261 pistons. I have seen a few manufactures floating around. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | There are probably only a few producers of piston castings for the 261, with a lot of people doing the finish machining and putting their own name on the box. When I worked at Armstrong Robber Co. we produced 4 brands of tires, using the same molds, rubber compounds and curing times- - - -we just changed the label inserts in the molds for "different" brand names. Jerry
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Egge uses the TRW number, may be actual remaining stock or just a convenient way to identify it. | | |
