4 members (thekid1950, Peggy M, RoadsScholar, Hanks custodian), 164 guests, and 2 robots.
Topics128,080
Posts1,056,063
Members48,433
V
VEW
Offline
V Offline
I'm starting to work on the bed for my 41 3/4 ton. I have an 8' bed from a 65 Jeep that I plan on using, but it needs work. I've been looking at replacing the bed stake pockets with ones from a 41-46 (available from J. Carter). But I would like to know the dimensions of them before purchasing. I inquired with them, but haven't heard back.
As you can see in the pics, the front is a bit over 17" long, and the rear is about 19".
If they are close, I think I can make them work. I mean, all I have to do is "cut and paste", right?
Thanks for your help.
~ Victor
1957 3100 - moved on
V
VEW
Offline
V Offline
Thanks for moving my thread Martin. Sorry I posted in the incorrect section.
~ Victor
No problem. I’ve got your back.
Have you looked at Mar-K’s website? They have lots of schematics on various beds and parts.🛠
V
VEW
Offline
V Offline
Will check it out, thanks.
~ Victor
V
VEW
Offline
V Offline
Got the dimensions.
Thanks.
~ Victor
