3 members (BC59, cmayna, Peggy M), 144 guests, and 2 robots.
Topics128,095
Posts1,056,475
Members48,444
#129086 05/04/2003 2:08 PM
I'm thinking about installing one of those aftermarket powerbrake units on my 52. The one with dual chambers and power that is supposed to bolt onto the frame where the original master cylinder is and use your current brakes.
Has anyone got an opinion on these units?
I like mine. grin
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
I need to rebuild my brakes as well and looking for dual chambers--but questioning whether I need to get a power booster. Any thoughts on the necessity of the power booster? Also anybody used one of these units with remote fill capability. Any junk yard solutions? Thanks. smile
Buzz'n Half Dozen
Buzzin' Half-If you check out many of the aftermarket "conversion" suppliers, you should find brackets available for swapping dual reservoir non-power master cylinders onto your rig. Try Classic Performance Products at:
www.classicperform.com
Also try our own sponsor (@ top of page) American Classic Truck Parts.
The non-power brackets are a wee bit cheaper than the power setups, I believe. Hope this helps.
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
