Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
0 members (), 478 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
The factory front anti-roll bar for the 67-72 trucks is 1” diameter. I plan to use one on my 63- 1/2T short bed. Vendors sell 1.125” diameter bars with down links to connect to the lower CA. I’m not thrilled with the appearance, but I do have one (yet to be installed).
Tonight I bought a factory 1T truck bar that is 1.25” diameter.
So my question is this, will I regret installing the thicker 1.25” bar from the 1T truck?
At some point, the action of an antiroll bar starts to affect what the rear end is doing. It's been quite some time since I spent my weekends campaigning an Austin-Healey 3000 in SCCA club races, but that's one way we would tinker with the handling for different road courses- - - -installing different diameter front and rear antiroll bars.. I have no idea how that kind of stuff would translate to how a pickup handles, but it will make a noticeable difference!
Well I also have a 3rd generation Camaro rear anti-roll bar that is commonly used for the rear in a 63-72 truck. I imagine there would be some frame twist with severe cornering, but I drive like an old man, so the two bars combined should eliminate any major body roll.
With an anti-sway bar at each end, I do not think you can go too big!
'57 Chevy Suburban; '70 Chevy Impala.
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.030s Queries: 14 (0.027s) Memory: 0.6081 MB (Peak: 0.6468 MB) Data Comp: Zlib Server Time: 2025-09-22 09:02:58 UTC
Valid HTML 5 and Valid CSS
